[Qgis-user] Multi users environment: From geopackage to a database?
Robert Nuske rsn.mailinglists at gmail.com
Wed May 6 03:22:18 PDT 2020
Hi Bruno,
another list of known issues with SQLite/GeoPackage and SAMBA in particular
https://trac.osgeo.org/gdal/wiki/UserDocs/SQLite
regards
  robert
Am 06.05.20 um 12:00 schrieb Stefan Keller:
> Hi,
> This should be IMHO an issue of highest priority for QGIS.
> Jésahel  wrote
>> I've created a script to deactivate wal on samba shares, because samba is the main issue.
>> It contains this only line : QSettings().setValue("/qgis/walForSqlite3", False)
> That's interesting. Are you sure it's Samba?
> SQLite FAQ [2] confirms that NFS has problems.
> Did not find issues on Samba, but file locking with fcntl is mentioned here [3].
> Goal should IMHO be that 1. No crash, 2. read-only multi-user access
> should be possible and 3. writing users must be warned if QGIS isn't
> able to exclusively open the file.
> And Jésahel  script suggests, that at least point 1 and 2 are possible.
> Andreas wrote:
>> Unfortunately it is a known issue that Geopackages and QGIS are bad at handling simultaneous write and even read requests
>> and developers are working on finding solutions (hopefully soon).
> The only issue I find on QGIS tracker is [1]. Am I missing something?
> :Stefan
> [1] https://github.com/qgis/QGIS/issues/23991
> [2] https://www.sqlite.org/faq.html#q5
> [3] https://www.samba.org/samba/docs/old/Samba3-HOWTO/locking.html
> Am Mi., 6. Mai 2020 um 10:42 Uhr schrieb Jésahel Benoist <djes1975 at gmail.com>:
>> Hi Bruno,
>> I've worked a lot on this issue for two years now. I've started with sqlite (that was faster and better) but finally I decided to migrate to geopackage. It was painful at first but now it's OK. But it needs some rules.
>> First, I've broken the original big geopackage files into smaller ones. The users are advised to work only one by one on a specific thematic/file (read access is possible).
>> I've created a script to deactivate wal on samba shares, because samba is the main issue. It contains this only line : QSettings().setValue("/qgis/walForSqlite3", False)
>> You should download some tools like Spatialite_GUI and SQLiteDatabaseBrowser so that you can really work on the db and have better control. QGIS's dbmanager is a bit limited and sometimes buggy for sqlite/geopackage, especially with special chars.
>> Try to work with QGIS internal explorer, it's a tool that has good export/import functions.
>> Backup files at least one time a day !
>> Now with the covid I have created my own online postgis server so that we can work at home without "help" of IT department and it's GREAT. Multi-user, faster, smaller, stronger (lol). And some nice capabilities like spatial filtering ! I highly recommend this.
>> Questions for all : I've recently discovered this https://gdal.org/user/virtual_file_systems.html#virtual-file-systems
>> Wouldn't it be possible to avoid samba's multi-users bug with vsi ?
>> Jésahel
>> Le mer. 6 mai 2020 à 09:12, Andreas Neumann <a.neumann at carto.net> a écrit :
>>> Hi Bruno,
>>> Unfortunately it is a known issue that Geopackages and QGIS are bad at handling simultaneous write and even read requests and developers are working on finding solutions (hopefully soon). In single user scenarios Geopackages are fine. But Multiuser must be avoided, even for reading only, unfortunately.
>>> As to PostgreSQL vs. Postgis: Postgis is the spatial extension of PostgreSQL. If you need geometries (which I assume) than you will need Postgis.
>>> Andreas
>>> Am 06.05.20 um 08:58 schrieb brunos at mailbox.org:
>>> Hi
>>> In my company we are five people who sometimes work with GIS, and we are moving from ArcGIS to QGIS (how cool is QGIS and SLYR!) and in this context from ESRI file geodatabase to geopackage. Today we run into serious issues when two people worked with the same geopackage. I was aware, that it is dangerous and unwise to edit the same geopackage from two different computers at the same time. But I did not expect both QGIS applications to crash immediately and the geopackage to get corrupted. I hoped to get a warning or simply not be able to enter edit mode (We later found out, that the corrupted geopackage could be recoveredby by adding a new table, this somehow fixed it. Whew!).
>>> Worse, I found that the same thing happens, when I open a QGIS project with a layer from a geopackage for display only (no edit mode), which is being edited by an other user on an other computer. Again, both QGIS application crashed immediately with data loss. Again, the non-responsive QGIS tasks could not be killed by windows taskmanager, only by restarting of the computers.
>>> We are using QGIS 3.12.2 on Windows 10. The Geopackages are located on a samba network share.
>>> My questions:
>>> 1. Is this setup that bad? Do you experience the same fatal consequences if someone loads a layer from a geopackage which is being edited by someone else? Is there something I do wrong or I that can do to improve the situation?
>>> 2. I realize, that we should probably move from geopackage to a database. Do we need PostGIS or can we use PostgreSQL? We don't need more functinality than a geopackage offers (exept multi user read/edit possibility and stability).
>>> Many thanks for some hints that put me in the right direction!
>>> Bruno
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200506/d1b5a0a8/attachment-0001.key>
