[Qgis-user] Captioning raster layers
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed May 6 06:47:51 PDT 2020
A raster database has not been developed yet in QGIS, unless it was recently add and don’t know about it. I did not know it could stored in the metadata. I know some metadata (Like layer name, file name) can queried as variables. Could this be used in a python script? Anyone???
Ultimately, you could do a raster to vector conversion and add the data in a new database. You could make that layer transparent but still access the dataset.
Nicolas Cadieux
Ça va bien aller!
> Le 6 mai 2020 à 00:03, Patrick Dunford <enzedrailmaps at gmail.com> a écrit :
> Good day
> As we know, for vector layers, we can caption the layers with any field that is stored in the data table that is incorporated into each layer.
> With a raster layer, there obviously isn't an equivalent data structure attached within the raster file itself, but within the properties assigned to each raster layer that is incorporated into a Qgis project are metadata fields that can be filled in and presumably this data is stored within the project file for the layer concerned.
> Given that there is this data stored then I think there is a question that it should be possible to display any of the fields as a caption when the raster layer is visible on the canvas and unfortunately I cannot find any way of doing this. As I currently use various raster layers in my projects that are from various dates I would prefer to have some way of displaying the date associated with each layer within the canvas and this does not appear to be possible at present with the software.
> Qgis-user mailing list
