[Qgis-user] error "Cannot zoom to selectet feature(s): No extent could be determined.""
DelazJ delazj at gmail.com
Wed May 13 07:30:29 PDT 2020
Another option: In the layer's properties --> Source tab, could you press
"update extents" and/or "create spatial index"?
If nothing changed, probably reload the layer to see..
Regards,
Harrissou
Le mer. 13 mai 2020 à 15:57, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
a écrit :
> Hi,
> Looks like the .shp (the geometries) no longer matches with the .dbf file
> (the data).  That file could be corrupted.  Did you manipulate the layer in
> an other software like ArcGIS, AutoCAD or  Mapinfo?  Did you delete
> objects?  Different programs have dif ways of erasing objects in shapefiles
> and that can lead to errors of this sort.  I would also check your hard
> drive for other errors?   This could be a simple HD error or the beginning
> of the end of a hard drive. You can look at the drive SMART status also.
> My first reaction would be to try exporting the file in an other format or
> with another name and see what happens.
> Nicolas Cadieux
> Ça va bien aller!
> > Le 13 mai 2020 à 06:43, Simon Niederbacher <niederbacher.simon at gmail.com>
> a écrit :
> > Hello,
> > I have a problem with my shape layers (type: line). I have a layer with
> > aprox. 500 line features. Since few days a thrid of those are not
> displayed
> > anymore on the map, but are still existing in the attribute table. When I
> > select one of those features and click on "zoom map to the selected
> rows", I
> > get the error "Cannot zoom to selectet feature(s): No extent could be
> > determined.
> > Does somebody have an idea what could be wrong with those line features?
> > Thank you a lot in advance.
> > regards
> > Simon
> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200513/f2158bb3/attachment.html>
