[Qgis-user] error "Cannot zoom to selectet feature(s): No extent could be determined.""
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed May 13 06:56:46 PDT 2020
Looks like the .shp (the geometries) no longer matches with the .dbf file (the data). That file could be corrupted. Did you manipulate the layer in an other software like ArcGIS, AutoCAD or Mapinfo? Did you delete objects? Different programs have dif ways of erasing objects in shapefiles and that can lead to errors of this sort. I would also check your hard drive for other errors? This could be a simple HD error or the beginning of the end of a hard drive. You can look at the drive SMART status also.
My first reaction would be to try exporting the file in an other format or with another name and see what happens.
Nicolas Cadieux
Ça va bien aller!
> Le 13 mai 2020 à 06:43, Simon Niederbacher <niederbacher.simon at gmail.com> a écrit :
> Hello,
> I have a problem with my shape layers (type: line). I have a layer with
> aprox. 500 line features. Since few days a thrid of those are not displayed
> anymore on the map, but are still existing in the attribute table. When I
> select one of those features and click on "zoom map to the selected rows", I
> get the error "Cannot zoom to selectet feature(s): No extent could be
> determined.
> Does somebody have an idea what could be wrong with those line features?
> Thank you a lot in advance.
> regards
> Simon
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
