[Qgis-user] vector point grid to raster grid -- pixel size does not work
Priv.-Doz. Dr. Maria Shinoto
maria.shinoto at zaw.uni-heidelberg.de
Thu May 14 00:46:19 PDT 2020
Chris,
Thank you for your ideas. I am trying now, but there are some questions:
> For this, rather than use the Raster > Rasterize tool, the approach should be:
> • open the processing toolbox Processing > Toolbox
> • in the toolbox open Interpolation > TIN interpolation
OK until this point
> • in the TIN Interpolation screen:
> • select the Vector layer
OK.
> • select the Interpolation attribute
First problem: I stored the vector layer in a Geopackage; so I have an fid from the geopackage database, an ID from the original xyz-File in field_1, and the x, y, z values in field_2, _3 and _4.
Which attribute should I choose? I think only field_2 and field_3?
There is a checkbox for the Z-coordinate, whether I with to use it for interpolation. I guess I leave unchecked?
> • click the + to add to the vector layer panel
So I added the two fields, they are "Points"
> • choose the interpolation method - probably best to use cubic
> • click on the ... next to extent and set it to the layer extent
OK
> • set the pixel size to 5.0 and 5.0
OK
> • click Run
OK
> This way you won't have the odd sizes you mentioned. This may give you a smoother surface in the end as well.
I started the prozess, but with more than 11 Million points, it seems to take too long, I am stuck at 50%. Will try later again.
Best,
Maria
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
