[Qgis-user] vector point grid to raster grid -- pixel size does not work
chris hermansen
clhermansen at gmail.com
Thu May 14 19:26:15 PDT 2020
María and list
On Thu, May 14, 2020, 00:46 Priv.-Doz. Dr. Maria Shinoto <
maria.shinoto at zaw.uni-heidelberg.de> wrote:
> Chris,
> Thank you for your ideas. I am trying now, but there are some questions:
> > For this, rather than use the Raster > Rasterize tool, the approach
> should be:
> > • open the processing toolbox Processing > Toolbox
> > • in the toolbox open Interpolation > TIN interpolation
> OK until this point
> > • in the TIN Interpolation screen:
> > • select the Vector layer
> OK.
> > • select the Interpolation attribute
> First problem: I stored the vector layer in a Geopackage; so I have an fid
> from the geopackage database, an ID from the original xyz-File in field_1,
> and the x, y, z values in field_2, _3 and _4.
> Which attribute should I choose? I think only field_2 and field_3?
No you just want the elevation field here I guess it's your _4?
> There is a checkbox for the Z-coordinate, whether I with to use it for
> interpolation. I guess I leave unchecked?
Yes
> > • click the + to add to the vector layer panel
> So I added the two fields, they are "Points"
Just the one field
> > • choose the interpolation method - probably best to use
> cubic
> > • click on the ... next to extent and set it to the layer
> extent
> OK
> > • set the pixel size to 5.0 and 5.0
> OK
> > • click Run
> OK
> > This way you won't have the odd sizes you mentioned. This may give you
> a smoother surface in the end as well.
> I started the prozess, but with more than 11 Million points, it seems to
> take too long, I am stuck at 50%. Will try later again.
You can always try IDW instead of TIN.
Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200514/6c1fe0e9/attachment.html>
