[Qgis-user] PostGIS Views in QGIS 3.10
Andreas Neumann
a.neumann at carto.net
Thu May 14 01:14:17 PDT 2020
Hi Vera,
As far as I know, the yellow triangle means that either something is
wrong with the layer, or that it needs a user input, such as "choosing a
primary key column" in case of a view.
It basically means that the layer can't be loaded, unless the user
provides a hint to QGIS how to correctly load the layer.
I don't think you can configure QGIS to not display these yellow
triangles for views. I also think they are useful indicator to the
users, that they need to do something.
It could also be a missing SRID, or something else.
Andreas
Am 14.05.20 um 09:22 schrieb Vera Diaz-Köhli:
> Hello
> We have made some views in our PostGIS-Database, so that it is easier
> for our users to access the data.
> The views have a column with a unique id ( Y ID).
> In the «Add PostGIS-Layer» dialog, all those view are listed, with
> the field «Object-ID» filled in correctly ( > ID) and they can be
> added to the map. However, there’s a little yellow triangle in front
> of their names, which only disappears, when I click in the field
> «Object-ID».
> How can I get rid of those yellow triangles? They are quite confusing
> for our user, even though the views do work…
> Thanks in advance
> Vera
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200514/a59e7340/attachment-0001.html>
