[Qgis-user] Viewshed From Specific Elevation?
cgray at graytechsoftware.com cgray at graytechsoftware.com
Thu May 14 14:48:46 PDT 2020
I’ve done what you described – select a point away from the edge and manually adjust the observer height. This does work.
I also tested negative observer height. If it is surrounded, the viewshed simply shows nothing (neighboring pixels only).
However, I’m going to be doing 100+ points over multiple locations. Ideally, when I setup a viewshed point (including elevation), I can just run an analysis from that location and ignore the first 2m or so. I think manipulating every point will be cumbersome.
Thank you, Chris
Sent: Thursday, May 14, 2020 5:36 PM
To: cgray at graytechsoftware.com; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Viewshed From Specific Elevation?
You could try converting the first lidar returns to a raster layer and using a negative elevation observer value or select point that is one or 3 pixels away from the edge of the roof.  I am not sure if the negative observer height will work but it may.  If you need to remove obstructions, you can create a mask and recalculate the elevations if the obsructions below the observer height and rerun the viewshed.
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
From: cgray at graytechsoftware.com <mailto:cgray at graytechsoftware.com>
Date: 2020-05-14 5:42 PM (GMT-04:00)
To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Viewshed From Specific Elevation?
I am attempting to test viewsheds from multiple heights below the roofline of particular buildings. I have been identifying viewing positions from directly from LiDAR data, but I cannot find a way to use absolute values for elevation.  The build-in visibility analysis seems to always use the raster elevation value plus the relative observer height.
I would like to use an absolute Z value, and have some immediate zone that is ignored (i.e., ignore the first 2m of obstructions) so that a viewpoint that might be lower than the raster elevation value can get outside of a building.
Is there a plugin or alternative visibility analysis tool that can do this? I was able to get it to work in Manifold Viewer, but I would like to keep the workflow within QGIS if possible.
Thank you, Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200514/46ca5175/attachment-0001.html>
