[Qgis-user] Viewshed From Specific Elevation?
Kirk Schmidt kirk at nortekresources.com
Fri May 15 04:56:43 PDT 2020
Chris:
Super. In retrospect, the negative observer height should come back with
a null result as you cannot see much if you are standing in a well.
You could run a buffer of 2 m around every observation point and
recalculate your raster DSM values to a set elevation (ie 10m) and
calculate your observation elevation by  subtracting 10 m from your
actual observation elevation.  That way, your observation height will be
modeled correctly.
Have fun
Kirk Schmidt
On 5/14/2020 6:48 PM, cgray at graytechsoftware.com wrote:
> I’ve done what you described – select a point away from the edge and
> manually adjust the observer height. This does work.
> I also tested negative observer height. If it is surrounded, the
> viewshed simply shows nothing (neighboring pixels only).
> However, I’m going to be doing 100+ points over multiple locations.
> Ideally, when I setup a viewshed point (including elevation), I can
> just run an analysis from that location and ignore the first 2m or so.
> I think manipulating every point will be cumbersome.
> Thank you, Chris
> *From:* kirk <kirk at nortekresources.com>
> *Sent:* Thursday, May 14, 2020 5:36 PM
> *To:* cgray at graytechsoftware.com; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Viewshed >From Specific Elevation?
> You could try converting the first lidar returns to a raster layer and
> using a negative elevation observer value or select point that is one
> or 3 pixels away from the edge of the roof.  I am not sure if the
> negative observer height will work but it may.  If you need to remove
> obstructions, you can create a mask and recalculate the elevations if
> the obsructions below the observer height and rerun the viewshed.
> Sent from my Samsung Galaxy smartphone.
> -------- Original message --------
> From: cgray at graytechsoftware.com <mailto:cgray at graytechsoftware.com>
> Date: 2020-05-14 5:42 PM (GMT-04:00)
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Viewshed From Specific Elevation?
> I am attempting to test viewsheds from multiple heights below the
> roofline of particular buildings. I have been identifying viewing
> positions from directly from LiDAR data, but I cannot find a way to
> use absolute values for elevation.  The build-in visibility analysis
> seems to always use the raster elevation value plus the relative
> observer height.
> I would like to use an absolute Z value, and have some immediate zone
> that is ignored (i.e., ignore the first 2m of obstructions) so that a
> viewpoint that might be lower than the raster elevation value can get
> outside of a building.
> Is there a plugin or alternative visibility analysis tool that can do
> this? I was able to get it to work in Manifold Viewer, but I would
> like to keep the workflow within QGIS if possible.
> Thank you, Chris
> Qgis-user mailing list
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200515/76b88741/attachment.html>
