[Qgis-user] Export GeoPDF Mac
    Andreas Neumann
    a.neumann at carto.net
    Sat May 16 02:07:46 PDT 2020
Hi Adam,
GDAL is an integral part of QGIS. QGIS doesn't work without GDAL. So I'm
100% sure that your colleague on Windows also has GDAL. Maybe you just
aren't aware of it. If you go to the about screen in the help menu. What
does it say there about GDAL? On your Mac and on the Windows
installation of your colleague?
Also: what QGIS version do you use on the Mac? GeoPDF is relatively new
and you need both a new GDAL and a new QGIS. But normally you don't have
to worry about GDAL. If you use the new MacOS all in one installer, GDAL
should be installed automatically with it. With the older way of
installing QGIS on the Mac you still had to install it separately. Both
approaches have advantages/disadvantages.
Greetings,
Andreas
Am 16.05.20 um 01:02 schrieb Adam Sneath:
> Hello there. I want to export a georeferenced PDF from my QGIS
> project, and I am unable to tick the box as I need GDAL 3.0. However,
> my colleague is using windows (I am using a mac) and he is able to
> export as a GeoPDF without any issue, despite him not having GDAL. I
> hoped you could help me towards a solution. Thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200516/30104520/attachment.html>
