[Qgis-user] distance to the coast
Ville Koivisto
ville.koivisto at kuntotekniikka.fi
Thu May 21 02:28:55 PDT 2020
Hi Nikos,
Other idea from the top of my head, you could create a point layer from your coast line (Qchainage, extract vertices…) and then run distance matrix between two point layers with 1 target points. Distance matrix output will give the closest point and distance to it. You might have to export your csv as shp or other vector format since I can’t recall if it’s possible to have csv as an input layer.
Best regards,
Ville Koivisto
+35840 701 4283
Head of GIS
Suomen kuntotekniikka Oy
[cid:image002.png at 01D62F6B.6433F0A0]
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Bernd Vogelgesang
Sent: Thursday, May 21, 2020 10:26 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] distance to the coast
Hi Nikos,
have you had a look at the NNJoin plugin?
Did not use it myself, but from what I read, it might serve your needs.
Cheers,
Bernd
On 21.05.20 08:34, Nikos Benos wrote:
Hello everybody,
As I am new to QGIS, I have the following question.
I have a shapefile of the coastline of Greece and I want to compute the minimum distance (haversine for now) between points contained in a csv file and the sea. How can I do that?
Thank you very much in advance for your help.
Best wishes,
Nikos Benos
Dr Nikos Benos
Associate Professor
Department of Economics
University of Ioannina
University Campus
45110 Ioannina
GREECE
Tel: +30-26510-05955
Fax: +30-26510-05092
e-mail: nbenos at uoi.gr<mailto:nbenos at uoi.gr>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200521/85a98ef9/attachment.html>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200521/85a98ef9/attachment.png>
