[Qgis-user] distance to the coast
Paolo Cavallini cavallini at faunalia.it
Thu May 21 02:38:20 PDT 2020
also v.distance from grass (also in Processing) will do
cheers
Il 21/05/20 11:28, Ville Koivisto ha scritto:
> Hi Nikos,
> Other idea from the top of my head, you could create a point layer from
> your coast line (Qchainage, extract vertices…) and then run distance
> matrix between two point layers with 1 target points. Distance matrix
> output will give the closest point and distance to it. You might have to
> export your csv as shp or other vector format since I can’t recall if
> it’s possible to have csv as an input layer.
> Best regards,
> Ville Koivisto
> +35840 701 4283
> Head of GIS
> Suomen kuntotekniikka Oy
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
> *Bernd Vogelgesang
> *Sent:* Thursday, May 21, 2020 10:26 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] distance to the coast
> Hi Nikos,
> have you had a look at the NNJoin plugin?
> Did not use it myself, but from what I read, it might serve your needs.
> Cheers,
> Bernd
> On 21.05.20 08:34, Nikos Benos wrote:
>     Hello everybody,
>     As I am new to QGIS, I have the following question.
>     I have a shapefile of the coastline of Greece and I want to compute
>     the minimum distance (haversine for now) between points contained in
>     a csv file and the sea. How can I do that?
>     Thank you very much in advance for your help.
>     Best wishes,
>     Nikos Benos
>     Dr Nikos Benos
>     Associate Professor
>     Department of Economics
>     University of Ioannina
>     University Campus
>     45110 Ioannina
>     GREECE
>     Tel: +30-26510-05955
>     Fax: +30-26510-05092
>     e-mail: nbenos at uoi.gr <mailto:nbenos at uoi.gr>
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Paolo Cavallini
www.faunalia.eu - QGIS.org
training, support, development on QGIS, PostGIS and more
