[Qgis-user] distance to the coast
Håvard Tveite havard.tveite at nmbu.no
Thu May 21 03:06:27 PDT 2020
The NNJoin plugin is perfect for the task, but if you
are using a recent QGIS version, the Processing algorithm
"Join attributes by nearest" (found in the "Processing
Toolbox) can do the same as the NNJoin plugin (and more).
Håvard
On 21.05.2020 09:26, Bernd Vogelgesang wrote:
> Hi Nikos,
> have you had a look at the NNJoin plugin?
> Did not use it myself, but from what I read, it might serve your needs.
> Cheers,
> Bernd
> On 21.05.20 08:34, Nikos Benos wrote:
>> Hello everybody,
>> As I am new to QGIS, I have the following question.
>> I have a shapefile of the coastline of Greece and I want to compute
>> the minimum distance (haversine for now) between points contained in a
>> csv file and the sea. How can I do that?
>> Thank you very much in advance for your help.
>> Best wishes,
>> Nikos Benos
>> Dr Nikos Benos
>> Associate Professor
>> Department of Economics
>> University of Ioannina
>> University Campus
>> 45110 Ioannina
>> GREECE
>> Tel: +30-26510-05955
>> Fax: +30-26510-05092
>> e-mail:nbenos at uoi.gr  <mailto:nbenos at uoi.gr>
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
