[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
Nyall Dawson
nyall.dawson at gmail.com
Tue May 26 15:42:45 PDT 2020
On Tue, 26 May 2020 at 03:59, Warren Medernach <wmedernach at gmail.com> wrote:
> QGIS version: 3.12.2-București
> ESRI Portal version: 10.7.1
> We have recently been testing out the access to our ESRI Enterprise Portal from QGIS using the ArcGisMapServer and ArcGisFeatureServer connectors. Our Portal is configured via SAML for Enterprise Logins using our corporate domain credentials as well as Built-In ArcGIS Portal users.
> We have tried the following Authentication methods: Basic Authentication using a built-in Portal user and Token based Authentication.
> It doesn't seem to matter which auth method we use, QGIS will only see content that is shared with Everyone in the Portal.
> Is it possible to connect to an ESRI Portal and have QGIS only show content the user has access to based on their settings in the ESRI Portal? ie. the Groups and Content they have access to.
I've had great experience using the o2 authentication setup and ESRI
Portal. In recent QGIS releases this is seamless and should exactly
match your needs.
Nyall
