[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
Warren Medernach
wmedernach at gmail.com
Tue May 26 16:35:26 PDT 2020
Thanks so much for the response Nyall, at least now we know something
should be possible.
Is there anyway you could share a screen cap, or provide some guidance for
the required settings in the OAuth2 dialog in QGIS.
Thanks again,
Warren
On Tue, May 26, 2020 at 4:42 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Tue, 26 May 2020 at 03:59, Warren Medernach <wmedernach at gmail.com>
> wrote:
> > QGIS version: 3.12.2-București
> > ESRI Portal version: 10.7.1
> > We have recently been testing out the access to our ESRI Enterprise
> Portal from QGIS using the ArcGisMapServer and ArcGisFeatureServer
> connectors. Our Portal is configured via SAML for Enterprise Logins using
> our corporate domain credentials as well as Built-In ArcGIS Portal users.
> > We have tried the following Authentication methods: Basic Authentication
> using a built-in Portal user and Token based Authentication.
> > It doesn't seem to matter which auth method we use, QGIS will only see
> content that is shared with Everyone in the Portal.
> > Is it possible to connect to an ESRI Portal and have QGIS only show
> content the user has access to based on their settings in the ESRI Portal?
> ie. the Groups and Content they have access to.
> I've had great experience using the o2 authentication setup and ESRI
> Portal. In recent QGIS releases this is seamless and should exactly
> match your needs.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200526/048e7657/attachment.html>
