[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
    Nyall Dawson
    nyall.dawson at gmail.com
    Tue May 26 16:54:20 PDT 2020
On Wed, 27 May 2020 at 09:35, Warren Medernach <wmedernach at gmail.com> wrote:
> Thanks so much for the response Nyall, at least now we know something should be possible.
> Is there anyway you could share a screen cap, or provide some guidance for the required settings in the OAuth2 dialog in QGIS.
Let me see if I can find time to write this up as a blog post later
today... there's a bit involved in the setup which I'd like to step
through
Nyall
> Thanks again,
> Warren
> On Tue, May 26, 2020 at 4:42 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Tue, 26 May 2020 at 03:59, Warren Medernach <wmedernach at gmail.com> wrote:
>> > QGIS version: 3.12.2-București
>> > ESRI Portal version: 10.7.1
>> > We have recently been testing out the access to our ESRI Enterprise Portal from QGIS using the ArcGisMapServer and ArcGisFeatureServer connectors. Our Portal is configured via SAML for Enterprise Logins using our corporate domain credentials as well as Built-In ArcGIS Portal users.
>> > We have tried the following Authentication methods: Basic Authentication using a built-in Portal user and Token based Authentication.
>> > It doesn't seem to matter which auth method we use, QGIS will only see content that is shared with Everyone in the Portal.
>> > Is it possible to connect to an ESRI Portal and have QGIS only show content the user has access to based on their settings in the ESRI Portal? ie. the Groups and Content they have access to.
>> I've had great experience using the o2 authentication setup and ESRI
>> Portal. In recent QGIS releases this is seamless and should exactly
>> match your needs.
>> Nyall
