[Qgis-user] Isochrone - problem
Riccardo D'Alvito
r.chogan at hotmail.com
Wed May 27 06:27:58 PDT 2020
Hi guys.
I am carrying out a viability analysis in which, starting from a series of points (contained in a layer) and from the city's infrastructure network, I want to draw the isochrones to understand the distance that can be reached in 5 minutes from those points.
Then I want to hypothesize the interruption (and/or slowdown) of some road sections to see how the isochrons change.
I have been advised to use some plugins like ORS Tool (which uses OpenStreetMap and so unfortunatelly I cannot assume the interruption of the road section), Hqgis (which I don't know how to use) and QNEAT3.
In QNEAT3 I'm able to insert the points layer and the road network layer but it says:
"The TIN-Interpolation algorithm in QGIS is designed to work with projected coordinate systems.Please use a projected coordinate system (eg. UTM zones) instead of geographic coordinate systems (eg. WGS84)!"
The problem is that my layers are in a projected coordinate system.
Do you know what can I do? Or if you know other ways to do isochrons with regular viability and assuming the interruption or slowdown of some road?
Thank you so much,
Riccardo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200527/01322443/attachment.html>
