[Qgis-user] wishing for accurate lattitude/longitude from, a cell phone
Garth Fletcher garth at jacqcad.com
Wed May 27 07:25:10 PDT 2020
Hi Ray,
Apologies for the typo - I had typed iGS3, but iG3s is the right number.
iGage <www.igage.com> iG3s, now replaced by the iG4 which adds Galileo
tracking but otherwise seems very similar to the iG3s. $2400 US.
These track satellites from the US GPS, Russian GLONASS, Chinese BeiDou
and, with the iG4, European Galileo constellations.
Their sole function is to record from all the satellites they can track.
They produce a RINEX format file which can be sent to a post processing
service such as Canada's Geodetic Surveys' CSRS-PPP:
<https://webapp.geod.nrcan.gc.ca/geod/tools-outils/ppp.php?locale=en>
The longer the observation (recording) duration, the better CSRS-PPP can
converge to an accurate location.  In my experience in New Hampshire's
heavily wooded environment, a 30 to 45 minute observation time generally
gets me to better than ± 1 meter accuracy.  Yesterday a 6 hour long
observation in a small field surrounded by forest converged to within 1
inch.  Dense forest canopy reduces the number of satellites that can be
tracked. Also, some times of day are better than others in terms of the
number of satellites and their geometry, see:
   <https://www.gnssplanning.com/#/charts>
The iG3s was perfect for my specific conditions, but I think it is not
optimal where many locations within a site must be accurately measured
** relative ** to each other.
Such sites would be better served by differential measuring where two
receivers are used.  One is the "Base" which is kept in a fixed location
while the other is the "Rover" which is moved from place to place.
The Base constantly transmits its data to the Rover over a RF link.  As
long as both are fairly close (within a few kilometers of each other),
both see essentially identical satellite errors which can be cancelled
out to produce a very precise ** difference ** in location between Base
and Rover.
Note that the absolute accuracy of their positions may not be as high,
but the relative accuracy can be at centimeter level.  In other words,
the absolute accuracy might be ± several meters, but the relative
accuracy will be ± centimeters.
Relative location is all that is needed for site mapping. Accurate
absolute location can then be determined by carefully measuring the
location of the Base, which only needs to be done once.
The major advantage is speed as there is no need for long observation
times at each location.  There is also no need for internet or cell
phone connectivity - the only requirement is that the Base be able to
transmit its data to the Rover at all locations of interest.
Earlier in this thread <https://emlid.com/reachrs/> was mentioned as one
source of such Base/Rover systems.  At $ 1600 per pair they woud be
less expensive than a single iG3s or iG4 and could be much more
effective.  However, I do not have any personal experience with such
instruments.
On 5/27/20 9:11 AM, QGIS.USER wrote:
> Hi Garth,
> 	Thank you for some very useful data. Mine own experience in archaeology fully supports your findings. Like most things in archaeology, money is scare, time is plentiful:-)  So when you talk about getting sub-metre accuracy using something called "iGS3", my interest peaked:-)  However, despite a reasonably thorough Google, nothing relevant turned up. What is a "iGS3" please?
> Thanks in advance.
> Ray Carpenter
> Chapel Archaeology.
Cordially
Garth Fletcher
