[Qgis-user] manual classification tool?
Raymond Nijssen r.nijssen at terglobo.nl
Thu May 28 02:50:05 PDT 2020
Ah, I found it! (With a little help from Richard..)
There is a widget type "Hidden" that prevents showing up on the form.
Still, if anyone knows of a way that also not needs to close the form
with an OK, could save me 17k extra mouse clicks. Using actions maybe?
Thanks,
Raymond
On 28-05-2020 10:31, Raymond Nijssen wrote:
> Hi Alex,
> Thanks, that is pretty close to what I'm looking for! I didn't manage to
> only show the widget for the field I want to edit though, so I'm seeing
> the entire form. I tried to find it in the Form and Fields properties
> and I tried to use hidden fields.
> Ray
> On 28-05-2020 09:24, Alexandre Neto wrote:
>> Hi Raymond,
>> Wouldn't the identify tool with auto open form with only the class
>> field widget available do that? Also, select tool with multi edit form
>> to classify several buildings in one go would save lots of clicks.
>> Alex
>> A quinta, 28/05/2020, 07:38, Raymond Nijssen <r.nijssen at terglobo.nl
>> <mailto:r.nijssen at terglobo.nl>> escreveu:
>>     Does anyone know if there is a tool in QGIS to quickly classify
>>     features
>>     manually?
>>     I have a layer with 17,000 buildings, all need to be set to 1 of 5
>>     values. I'm thinking about making a (quick and dirty) plugin that:
>>     - On clicking the building shows a popup menu with the 5 choices
>>     - Clicking the choice would update the value and change the color
>>     (redraw)
>>     Every click less really counts here. I already set up a form
>> widget but
>>     also having the location of the menu near the building polygon is way
>>     more efficient. (I mean, no need to cross the screen with your mouse
>>     cursor.)
>>     Thanks!
>>     Raymond
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
