[Qgis-user] manual classification tool?
Raymond Nijssen r.nijssen at terglobo.nl
Thu May 28 01:31:51 PDT 2020
Hi Alex,
Thanks, that is pretty close to what I'm looking for! I didn't manage to
only show the widget for the field I want to edit though, so I'm seeing
the entire form. I tried to find it in the Form and Fields properties
and I tried to use hidden fields.
Ray
On 28-05-2020 09:24, Alexandre Neto wrote:
> Hi Raymond,
> Wouldn't the identify tool with auto open form with only the class field
> widget available do that? Also, select tool with multi edit form to
> classify several buildings in one go would save lots of clicks.
> Alex
> A quinta, 28/05/2020, 07:38, Raymond Nijssen <r.nijssen at terglobo.nl
> <mailto:r.nijssen at terglobo.nl>> escreveu:
>     Does anyone know if there is a tool in QGIS to quickly classify
>     features
>     manually?
>     I have a layer with 17,000 buildings, all need to be set to 1 of 5
>     values. I'm thinking about making a (quick and dirty) plugin that:
>     - On clicking the building shows a popup menu with the 5 choices
>     - Clicking the choice would update the value and change the color
>     (redraw)
>     Every click less really counts here. I already set up a form widget but
>     also having the location of the menu near the building polygon is way
>     more efficient. (I mean, no need to cross the screen with your mouse
>     cursor.)
>     Thanks!
>     Raymond
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
