[Qgis-user] manual classification tool?
Alexandre Neto
senhor.neto at gmail.com
Thu May 28 00:24:16 PDT 2020
Hi Raymond,
Wouldn't the identify tool with auto open form with only the class field
widget available do that? Also, select tool with multi edit form to
classify several buildings in one go would save lots of clicks.
Alex
A quinta, 28/05/2020, 07:38, Raymond Nijssen <r.nijssen at terglobo.nl>
escreveu:
> Does anyone know if there is a tool in QGIS to quickly classify features
> manually?
> I have a layer with 17,000 buildings, all need to be set to 1 of 5
> values. I'm thinking about making a (quick and dirty) plugin that:
> - On clicking the building shows a popup menu with the 5 choices
> - Clicking the choice would update the value and change the color (redraw)
> Every click less really counts here. I already set up a form widget but
> also having the location of the menu near the building polygon is way
> more efficient. (I mean, no need to cross the screen with your mouse
> cursor.)
> Thanks!
> Raymond
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200528/6878d132/attachment.html>
