[Qgis-user] manual classification tool?
Werner Macho
werner.macho at gmail.com
Thu May 28 03:01:21 PDT 2020
Hi Raymond,
Sounds like a blogpost with a nice explanation, that is a problem I also
have sometimes (though not with 17K).
Once you solved it it would be nice to have a manual howto get there.
regards
Werner
On Thu, May 28, 2020 at 11:58 AM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Yup, hidden widget was what I was thinking.
> A custom python form can probably provide what you want. I think you will
> be able to listen to that specific field widget and close the form when it
> changes
> Alex
> A quinta, 28/05/2020, 10:50, Raymond Nijssen <r.nijssen at terglobo.nl>
> escreveu:
>> Ah, I found it! (With a little help from Richard..)
>> There is a widget type "Hidden" that prevents showing up on the form.
>> Still, if anyone knows of a way that also not needs to close the form
>> with an OK, could save me 17k extra mouse clicks. Using actions maybe?
>> Thanks,
>> Raymond
>> On 28-05-2020 10:31, Raymond Nijssen wrote:
>> > Hi Alex,
>> > Thanks, that is pretty close to what I'm looking for! I didn't manage
>> to
>> > only show the widget for the field I want to edit though, so I'm seeing
>> > the entire form. I tried to find it in the Form and Fields properties
>> > and I tried to use hidden fields.
>> > Ray
>> > On 28-05-2020 09:24, Alexandre Neto wrote:
>> >> Hi Raymond,
>> >> Wouldn't the identify tool with auto open form with only the class
>> >> field widget available do that? Also, select tool with multi edit form
>> >> to classify several buildings in one go would save lots of clicks.
>> >> Alex
>> >> A quinta, 28/05/2020, 07:38, Raymond Nijssen <r.nijssen at terglobo.nl
>> >> <mailto:r.nijssen at terglobo.nl>> escreveu:
>> >> Does anyone know if there is a tool in QGIS to quickly classify
>> >> features
>> >> manually?
>> >> I have a layer with 17,000 buildings, all need to be set to 1 of 5
>> >> values. I'm thinking about making a (quick and dirty) plugin that:
>> >> - On clicking the building shows a popup menu with the 5 choices
>> >> - Clicking the choice would update the value and change the color
>> >> (redraw)
>> >> Every click less really counts here. I already set up a form
>> >> widget but
>> >> also having the location of the menu near the building polygon is
>> way
>> >> more efficient. (I mean, no need to cross the screen with your
>> mouse
>> >> cursor.)
>> >> Thanks!
>> >> Raymond
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200528/cdb605d9/attachment.html>
