[Qgis-user] manual classification tool?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu May 28 04:30:43 PDT 2020
I see many people have responded exactly to your question so I have a question for you. I am playing the devil’s advocate.  What are your classification?  Can any of this be classified any other way than manually? You could save time if you could preclassify building and only check the results manually?  Can size, shape, or colour help?  Can you use another data base like a city map or sensor data help?  Can you use satellite images to do some preclassification?  Have you thought of using AI with aerial photography?
If not, can you build a tool that will permit you to select multiple buildings at a time and only enter the information once?
Nicolas Cadieux
Ça va bien aller!
>> Le 28 mai 2020 à 02:33, Raymond Nijssen <r.nijssen at terglobo.nl> a écrit :
> Does anyone know if there is a tool in QGIS to quickly classify features manually?
> I have a layer with 17,000 buildings, all need to be set to 1 of 5 values. I'm thinking about making a (quick and dirty) plugin that:
> - On clicking the building shows a popup menu with the 5 choices
> - Clicking the choice would update the value and change the color (redraw)
> Every click less really counts here. I already set up a form widget but also having the location of the menu near the building polygon is way more efficient. (I mean, no need to cross the screen with your mouse cursor.)
> Thanks!
> Raymond
> Qgis-user mailing list
