[Qgis-user] Save projects to DB without creator's permissions
Cliff Patterson cpatterson at psdrcs.com
Fri May 29 10:29:30 PDT 2020
What is the best approach to save QGIS projects to PostgreSQL
without saving the project-creator's credentials/permissions? If the DB
admin creates a project and saves it to the DB, anyone opening that project
will attain the admin's permissions on layers in that map.
To recreate:
1) Create a map containing PostGIS layers and save project to DB. All
layers should be editable by the admin. Admin is logged into DB with auth
config, not basic auth.
2) Create a new read-only user and new profile in QGIS and log in to DB.
3) Open the project and try to edit layers. Read-only user will be able to
see and edit all layers just like the DB Admin.
Is there a way to save projects to DB WITHOUT saving any user
creds/permissions?
Cliff
Cliff Patterson Ph.D.
*PSD* | Senior GIS Consultant
P: 519-690-2565 ext. 2616
www.psdrcs.com
London | 148 Fullarton St. 9th Floor
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200529/0203635e/attachment.html>
