[Qgis-user] Save projects to DB without creator's permissions
Cliff Patterson cpatterson at psdrcs.com
Fri May 29 10:39:15 PDT 2020
PS: I realize I can create maps with basic auth and not store the PW, which
prompts the user to enter their creds. But is there a better way now to
achieve the same result?
Cliff
On Fri, May 29, 2020 at 1:29 PM Cliff Patterson <cpatterson at psdrcs.com>
wrote:
> What is the best approach to save QGIS projects to PostgreSQL
> without saving the project-creator's credentials/permissions? If the DB
> admin creates a project and saves it to the DB, anyone opening that project
> will attain the admin's permissions on layers in that map.
> To recreate:
> 1) Create a map containing PostGIS layers and save project to DB. All
> layers should be editable by the admin. Admin is logged into DB with auth
> config, not basic auth.
> 2) Create a new read-only user and new profile in QGIS and log in to DB.
> 3) Open the project and try to edit layers. Read-only user will be able to
> see and edit all layers just like the DB Admin.
> Is there a way to save projects to DB WITHOUT saving any user
> creds/permissions?
> Cliff
> Cliff Patterson Ph.D.
> *PSD* | Senior GIS Consultant
> P: 519-690-2565 ext. 2616
> www.psdrcs.com
> London | 148 Fullarton St. 9th Floor
www.psdrcs.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200529/00d84d5b/attachment.html>
