[Qgis-user] Problem exporting to pdf
António Pestana
afsm.pestana at gmail.com
Sun Nov 15 03:56:03 PST 2020
Bom dia Jorge.
I don't know what the "layer tree" is... I did change the name of the layer
(in the layers panel) to ASCII characters only but had no luck. In order to
solve this problem I had to change the name of the four files of the
shapefile accordingly.
Regards
Jorge Gustavo Rocha <jgr at geomaster.pt> escreveu no dia sábado, 14/11/2020
à (s) 21:21:
> Boa noite António,
> Just rename the layer (in QGIS layer tree) from "Todas as Parcelas Ãreas"
> to "Todas as Parcelas Areas".
> Then you will be able to export the layer :-)
> Please file a issue at [1]. Layers with such names should be supported.
> Regards,
> Jorge Gustavo
> [1] https://github.com/qgis/QGIS/issues
> Ãs 20:32 de 14/11/20, António Pestana escreveu:
> I´m using QGIS Desktop 3.16 on W10. My project (see All_Data.zip) has
> only two shapefile layers, one for polygons (Todas as Parcelas Ãreas)
> and the other for lines (Todas as Parcelas Linhas). I used a very
> simple layout for exporting my map to one layered geopdf. If I use the
> default export options (see Options_NOT_OK.PNG) export aborts throwing
> the "Could not create print device" error. However if I uncheck the
> "Include Attributes" checkbox of the export options (see
> options_OK.PNG), the export is made and the resulting pdf file looks
> fine.... Does someone know what is happening?
> Regards
> António
> Qgis-user mailing listQgis-user at lists.osgeo.org
> [image: Logo] <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:* jgr at geomaster.pt | *m:* +351 910 333 888
> *g:* 41.54094,-8.40490 | *v: * 510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201115/114e8858/attachment-0001.html>
