[Qgis-user] Set map grid CRS to follow map CRS?
Yoann QUENACH DE QUIVILLIC yquenach at itlink.fr
Mon Sep 21 02:28:52 PDT 2020
Hi Michael.
You have to keep it blank. If no CRS is set for the grid, it uses the map's
CRS. When you first add the grid to the map, its CRS is unset by default
(at least in QGIS 3.10).
However, there is not an obvious option to clear the grid CRS once you have
set it.
The trick is to select a section (i.e "Geographic Coordinate Systems") in
the CRS Selector instead of a specific CRS, then to click OK.
Regards
Le lun. 21 sept. 2020 à 06:38, Michael Dufty <MDufty at mbsenvironmental.com.au>
a écrit :
> I have set up some layout templates including a map grid.
> This works quite nicely, except I seem to have to choose a fixed CRS for
> the map grid.
> Is there any way to tell the map grid to use the CRS of the map it is
> attached too?  There doesn’t seem any obvious place to enter an expression,
> which seems unlike QGIS.
> It seems like it must be the most common choice of map grid people would
> want.  Am I just looking in the wrong place or is it a missing feature?
> Michael Dufty
> Qgis-user mailing list
<https://www.itlink.fr/>
Yoann Quenach de Quivillic
Ingénieur d'étude
www.itlink.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200921/ffdd3120/attachment.html>
