[Qgis-user] authomatic georeferencing or positioning of a feature
Mary Neale
mary at maryneale.co.uk
Mon Apr 12 00:58:20 PDT 2021
Hi there
If I were to Take a photo on a mobile phone with geolocation turned on,
could I then upload the data into Qgis to accurately plot it?
Many thanks Mary
On 11/04/2021 19:36, Bernd Vogelgesang wrote:
> Hi Paddy,
> you have to understand the concept, that attributes of a feature have
> noting to do with its geometry.
> The attributes table can hold any kind of information, in case of
> point layer of course its coordinates as well, but those values will
> not change when you change the geometry nor vice versa They are simply
> some numbers filled into that table.
> So you could e.g. drag the wrong positioned points to their correct
> locations (node tool) and then fill in the coordinates via the field
> calculator ($y and $x, see the documentation), but this is more or
> less only "cosmetic" as this information is in most cases not really
> helpfull.
> In case of towns, there is actually no such thing as a "correct"
> coordinate of a representing point, or it is at least pseudo-correct.
> Cheers,
> Bernd
> On 11.04.21 19:28, Pat Brown wrote:
>> Hi
>> I am having a problem with changing co-ordinate in my attribute table.
>> I am using QGIS 3.18 on WIN 97,so far without any issues.
>> It is a point layer with towns and their co-ordinates. Three of these
>> data points had empty co-ordinate records and they displayed way out of
>> position. This was already a mystery as I couldn't figure out how it could
>> display without these. I then filled in the correct co-ordinates but the
>> points are still displaying incorrectly.
>> Then I noticed that on the "identify feature" panel there is a subunit
>> called (Derived) and it says (clicked coordinate X and Y). How do I edit
>> this or get rid of this?
>> Many thanks,
>> Paddy
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210412/5b220d75/attachment.html>
