[Qgis-user] authomatic georeferencing or positioning of a feature
Philip Barlow
philipb at pembrokeshirecoast.org.uk
Mon Apr 12 01:11:35 PDT 2021
Hi Mary,
If you use the âimport geotagged photosâ processing tool, yes. It will create a point from the GPS coordinates in the image header. How accurate it will be will be dependent on your device and how good the GPS signal was.
Phil
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Mary Neale
Sent: 12 April 2021 08:58
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] authomatic georeferencing or positioning of a feature
Hi there
If I were to Take a photo on a mobile phone with geolocation turned on, could I then upload the data into Qgis to accurately plot it?
Many thanks Mary
On 11/04/2021 19:36, Bernd Vogelgesang wrote:
Hi Paddy,
you have to understand the concept, that attributes of a feature have noting to do with its geometry.
The attributes table can hold any kind of information, in case of point layer of course its coordinates as well, but those values will not change when you change the geometry nor vice versa They are simply some numbers filled into that table.
So you could e.g. drag the wrong positioned points to their correct locations (node tool) and then fill in the coordinates via the field calculator ($y and $x, see the documentation), but this is more or less only "cosmetic" as this information is in most cases not really helpfull.
In case of towns, there is actually no such thing as a "correct" coordinate of a representing point, or it is at least pseudo-correct.
Cheers,
Bernd
On 11.04.21 19:28, Pat Brown wrote:
Hi
I am having a problem with changing co-ordinate in my attribute table.
I am using QGIS 3.18 on WIN 97,so far without any issues.
It is a point layer with towns and their co-ordinates. Three of these
data points had empty co-ordinate records and they displayed way out of
position. This was already a mystery as I couldn't figure out how it could
display without these. I then filled in the correct co-ordinates but the
points are still displaying incorrectly.
Then I noticed that on the "identify feature" panel there is a subunit
called (Derived) and it says (clicked coordinate X and Y). How do I edit
this or get rid of this?
Many thanks,
Paddy
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.wales
Follow us on Twitter
Join us on Facebook
Watch us on Youtube
Look at us on Flickr
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
Click here to view PCNPA Privacy Notice Keeping your Information Safe
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.wales
Please consider the environment before printing this email.
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â dinistrio pob copi a rhoi
gwybod i'r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Cliciwch yma i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar www.arfordirpenfro.cymru
Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210412/73ff0b5d/attachment.html>
