[Qgis-user] authomatic georeferencing or positioning of a feature
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Mon Apr 12 01:15:26 PDT 2021
Hi Mary,
Depends on whether you have turned your geolocation on in your camera
settings.
Recently we have added the function in https://inputapp.io (a mobile app
based on QGIS) which records location and direction of the photos you take:
https://twitter.com/lutraconsulting/status/1380811414932164610
I hope it helps.
Kind regards
Saber
On Mon, 12 Apr 2021 at 09:06, Mary Neale <mary at maryneale.co.uk> wrote:
> Hi there
> If I were to Take a photo on a mobile phone with geolocation turned on,
> could I then upload the data into Qgis to accurately plot it?
> Many thanks Mary
> On 11/04/2021 19:36, Bernd Vogelgesang wrote:
> Hi Paddy,
> you have to understand the concept, that attributes of a feature have
> noting to do with its geometry.
> The attributes table can hold any kind of information, in case of point
> layer of course its coordinates as well, but those values will not change
> when you change the geometry nor vice versa They are simply some numbers
> filled into that table.
> So you could e.g. drag the wrong positioned points to their correct
> locations (node tool) and then fill in the coordinates via the field
> calculator ($y and $x, see the documentation), but this is more or less
> only "cosmetic" as this information is in most cases not really helpfull.
> In case of towns, there is actually no such thing as a "correct"
> coordinate of a representing point, or it is at least pseudo-correct.
> Cheers,
> Bernd
> On 11.04.21 19:28, Pat Brown wrote:
> Hi
> I am having a problem with changing co-ordinate in my attribute table.
> I am using QGIS 3.18 on WIN 97,so far without any issues.
> It is a point layer with towns and their co-ordinates. Three of these
> data points had empty co-ordinate records and they displayed way out of
> position. This was already a mystery as I couldn't figure out how it could
> display without these. I then filled in the correct co-ordinates but the
> points are still displaying incorrectly.
> Then I noticed that on the "identify feature" panel there is a subunit
> called (Derived) and it says (clicked coordinate X and Y). How do I edit
> this or get rid of this?
> Many thanks,
> Paddy
> Qgis-user mailing listQgis-user at lists.osgeo.org
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210412/d7e878b3/attachment-0001.html>
