[Qgis-user] Upload multiple models to the QGIS hub.
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Aug 13 19:05:03 PDT 2021
Thanks for the info!
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 13 août 2021 à 10:02, Charles Dixon-Paver <charles at kartoza.com> a écrit :
> I think this could be something that the platform could maybe be extended to manage a bit better, but for now I think maybe just creating a public git repo that uses the resource sharing plugin is best.
> You can then upload each model individually and add references to the other models and the complete resources plugin, assuming your models perform specific functions effectively as they are described.
>> On Fri, 13 Aug 2021 at 15:24, Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> I am working on a series of models who’s goal of to fix network (graph) problems (e.i. Find disconnected nodes, lines that run in circles, parallel edges…). The goal is to create a perfect network file so that no tolerance variable must be used when making a network analysis like shortest path and to track all changes to the file. This probably should have been made as a plugin but I wanted to experiment with models.
>> The model, being too complicated, I decided to split it in 3 parts. 1) explores, fixes and repairs the geometries, 2) explores and finds the network errors and 3) fixes the errors based on the informations found in models 1 and 2.
>> Anyways, I see I can upload the individual models to HUB but can I upload all 3 as a single download as a package? Just trying to figure out the easiest way to make sure the users downloads all 3 models…
>> Comments welcomed
>> Nicolas Cadieux
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/e22eb628/attachment.html>
