[Qgis-user] Layer Ordering for KMZ
krishna Ayyala
ayyalakrishna at gmail.com
Sat Aug 14 07:30:28 PDT 2021
Dear Sir,
Thanks for your reply. I tried to rename the KML files and also the
shapefiles. I have re-named small points as "A_Smal_Points" and big points
as "B_Big_Points". But still "B_Big_Points" is falling on top of
"A_Smal_Points". My task requires "A_Smal_Points" to fall on top of
"B_Big_Points".
Regards.
On Fri, Aug 13, 2021 at 6:27 PM Fernando M. Roxo da Motta <petro at roxo.org>
wrote:
> On Fri, 13 Aug 2021 17:08:24 -0600, krishna Ayyala
> <ayyalakrishna at gmail.com> wrote:
> Hi,
> I don't really know the answer to your question, bu it really looks
> like GE is laying those in alphabetical order. I don't know if the
> name is based in the file name or in some content of the file, but you
> could try to rename the .KML files or just the layers in Qgis before
> export.
> Just my 2¢, HTH.
> > Hello,
> > I have a QGIS map with two vector point layers. Layer 1 is
> > "Small_Points" and Layer 2 is "Big_Points". I have the KML tool
> > plugin installed. I have exported each of these layers using "Export
> > KMZ" tool. Everything exported well including the symbology.
> > But When I add these two KMZ layers to the google earth, always
> > "Big_Points" layer appears on top of "Small_Points" layer. In the
> > table of contents, I tried to move "Small_Points" layer on top of
> > "Big_Points" layer. Despite of that "Big_Points" layer appears on
> > top of "Small_Points" layer on the map. Can anyone help me fix this
> > such that "Small_Points" appear on top of "Big_Points".
> > Regards.
> Roxo
> ---------------- Non luctari, ludare -------------------+ WYSIWYG
> Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
> Except where explicitly stated I speak on my own behalf.| VI !!
> PU5RXO | PX5Q6048 | I see text,
> ------------ Quis custodiet ipsos custodes?-------------+ I get text!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210814/513f6dc7/attachment.html>
