[Qgis-user] What is postgresql client version and does it have anything to do with different postgresql versions
chris hermansen clhermansen at gmail.com
Tue Feb 2 13:59:34 PST 2021
Jeroen and list,
On Tue, Feb 2, 2021 at 12:37 PM Groene Bij <mail at groenebij.nl> wrote:
> Hi list,
> PostgreSQL has this interesting versioning where they try to keep like 5
> main branches up to date.
> At this point you can choose any version from 9.6.x up to 13.x
> Also, PostGIS is now slowly but probably steadily moving from 2.5.x to
> 3.1.x
> So, setting up a new PostgreSQL database environment  makes me wonder
> which one to choose.
> Since I will only be using this database with QGIS and QGIS 3.16 becoming
> the new LTR, does QGIS favor one of the PostgreSQL and PostGIS version
> above another?
> I did notice in the info screen for qgis3.16.3 it says PostgreSQL Client
> version 11.5
> Does that mean QGIS3.16 might work best with PostgreSQL 11.x? Or are they
> completely unrelated?
> What O/S do you use?  I ask because if it's Linux of some sort, your
repositories may be a good indicator.
This is worth a quick look https://www.postgresql.org/developer/roadmap/
Also this https://www.postgresql.org/support/versioning/
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210202/20dae2e6/attachment.html>
