[Qgis-user] Georeferencing a DXF file
Andreas Neumann
a.neumann at carto.net
Thu Feb 4 00:23:04 PST 2021
Hi all,
If I may chime in:
this is a long-standing user wish - being able to georeference vector
files in QGIS (in an easy way). This needs to go into core, not as a
plugin that breaks with future QGIS releases or has dependency issues.
The same discussion also pops up in the Swiss and QGIS user group e-mail
lists again and again and I believe it should be able to come up with
funding, if some developer could take the lead on implementing this in
QGIS core. I was hoping that Jürgen would be available to implement it,
as he also did the DXF/DWG importer and it would make sense, that the
DXF/DWG importer also integrates with a vector georeferencing solution.
Jürgen - would you be available to work on it? Or Alex?
Would someone be available to summarize the requirements and approaches
in a QEP? I think this would help tremendously, writing down the
requirements. Unfortunately, I don't have time currently to work on the
QEP myself. But I will help to find funding to get this functionality
into QGIS core.
Thanks,
Andreas
On 2021-02-03 20:10, Walt Ludwick wrote:
> I've received a 3D AutoCAD file from an architect that i managed to
> convert into 2D .dxf format and import into my QGIS project, but it is
> out-of-scale and out-of-place, so i guess i need to add some
> georeferencing coordinates to the file.
> This should be easy enough, since it's an accurate representation of a
> building that's already in the project -with an additional wing tacked
> on- so i'm thinking i could just use a few corners of that existing
> buildings as ground control points, and map them to the corresponding
> corners on this .dxf model, then maybe all other co-ordinates could be
> automatically generated by some tool, if i could just find the right
> one for the job.
> Is there in fact any such easy way to do this thing?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210204/863eadb3/attachment.html>
