[Qgis-user] distance between rectangle polygon in Qgis
Marin Mirosevic
marin.mirosevic at bouvet.no
Tue Feb 16 08:28:34 PST 2021
Calvin ,
This works now i get polygon with polygon lenghts on the sides in the map view, I have left [Create temporary layer] and it works 😊. Both map view and in the table is possible to see the lengths
many thanks
Marin Mirosevic
Fra: C Hamilton <adenaculture at gmail.com>
Sendt: Tuesday, February 16, 2021 2:51 PM
Til: Marin Mirosevic <marin.mirosevic at bouvet.no>; qgis-user <qgis-user at lists.osgeo.org>; Nicolas Cadieux <nicolas.cadieux at archeotec.ca>; kirk at nortekresources.com
Emne: Re: [Qgis-user] distance between rectangle polygon in Qgis
This is a processing algorithm and when you just put a name in the "Output layer" it is going to try and save the file somewhere local to the QGIS installation, but you don't have permission to save it there and it results in an error.
Either leave that field set to "[Create temporary layer]" or click on the "..." to the right and select "Save to File..." Give it a file name and then you will have the complete path where it will be saved.
Happy QGISing!
Calvin
On Tue, Feb 16, 2021 at 3:45 AM Marin Mirosevic <marin.mirosevic at bouvet.no<mailto:marin.mirosevic at bouvet.no>> wrote:
Hi Calvin,
I installed that what you proposed , thanks. However I get this error message
regards
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210216/da7c2262/attachment.html>
