[Qgis-user] Recent Projects Must be 1 or more - How to limit number of "Recent Projects" listed - Correction
Jeff Sonnentag
jsonnentag at llenviroinc.com
Tue Feb 16 15:30:19 PST 2021
Well, I shouldn't have spoken so fast about it working OK with a setting of 0 for "Recent Projects". I didn't try to save anything.
When I later did try to save something it saved but then immediately crashed/closed. Searching for that "feature"/behavior I found something about that having to do with old QGIS files being around and to reinstall, but that didn't make any sense.
So I changed the Recent Projects variable to 1 and it works right again. So apparently you CANNOT use 0 as the number of Recent Projects. I switched it back and forth a couple times and it did the same thing and it is 100% repeatable.
OK, I got another response from Etienne Trimaille about that setting in "Apps" in "Advanced" in "Settings". I thought something must be hiding somewhere, but had no idea where to look.
It's all set to 0 and working fine.
I don't know what it does with those default 20 most recent projects on the list that slows things down, but it certainly makes a difference.
From: David Strip <qgis-user at stripfamily.net<mailto:qgis-user at stripfamily.net>>
Sent: Monday, February 15, 2021 8:31 PM
To: Jeff Sonnentag <jsonnentag at llenviroinc.com<mailto:jsonnentag at llenviroinc.com>>; qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Subject: Re: [Qgis-user] How to limit number of "Recent Projects" listed - Correction
If you just want to hide the recent projects on the opening screen, go to Settings->General->Project Files and select something other than "Most Recent" "Welcome Page".
[cid:image001.png at 01D70478.A17190C0]
If you still want a list of recent projects, but a shorter list, go to Settings->Advanced and search for maxRecent and change the value. This will also change the length of the list of recent projects in Project->Open Recent
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210216/98c4b995/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210216/98c4b995/attachment.png>
