[Qgis-user] Scale bar length: mismatch between stated length and measured length
    Hernán De Angelis
    variablestarlight at gmail.com
    Thu Feb 18 00:17:03 PST 2021
I am experiencing a weird issue with the scale bar length: the stated
length does not match the measured length. This happens in several
projects, both existing and new. In all tested cases both layer and
project CRS are the same and there is no EPSG:3857, 4326 or layers that
use mixed CRS. The default unit is meters. Also, the mismatch is far
greater than any difference between ellipsoidal and cartesian distances.
See example below in UTM44N, but also seen in 18S and 34N.
Any idea of what may be wrong here?
Using QGIS 3.16.3, with PROJ 7.2.1.
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210218/957bb23e/attachment-0001.png>
