[Qgis-user] QGIS server WMS cascade getfeatureinfo
Karl Magnus Jönsson
Karl-Magnus.Jonsson at kristianstad.se
Thu Feb 18 05:37:21 PST 2021
Hi!
I don't have the same setup but I do some cascading WMS. I can usually get some hints from the QGIS Server log if there are problems. Maybe also look at the requests that the client sends to the server.
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För frippe12573
Skickat: den 18 februari 2021 11:03
Till: qgis-user at lists.osgeo.org
Ämne: [Qgis-user] QGIS server WMS cascade getfeatureinfo
Hi all,
I know that WMS cascade in QGIS server should be possible.
However, I have problems in visualization.
The WMS is originally served by geoserver and the preview is well rendered as well as getfeatureinfo works fine.
The same WMS loaded in a QGIS project works fine, and the getfeatureinfo returns the right information.
So I set the layer as WMTS in the QGIS project properties and I set the WCS capabilities for the layer.
Then I set the layer in the Lizmap plugin, enabling the popup and get layer from third parties.
The result on the client is that the layer is listed in the table of contents the legend is not visible and the layer is not visible and queriable.
I posted the same question in the
Lizmap mailing list without any answer so far.
Do you have any clue?
QGIS server version > 3.0
Thank you in advance for any answer.
Regards,
Eugenio
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
