[Qgis-user] getting a base map from Mapbox
Stephen Sacks
ssacks456 at gmail.com
Thu Feb 18 14:38:42 PST 2021
For the first time, I'm trying to use a map from Mapbox as a base map in
QGIS. I opened an account at Mapbox.com and made a map there using
their "Satellite streets." I clicked Publish and chose Publicly
available. I copied that map's Style URL and Access token and plugged
them and my Mapbox username into what I believe is the correct endpoint
template. Then back at my desktop QGIS, I clicked Layer > Add Layer
>Add WMS/WMTS layer > new . Then I entered a name and plugged in my
custom endpoint URL. Then I clicked OK and saw at the bottom "93546 of
93546 bytes of capabilities downloaded." Then I clicked Connect and got
the following message: "Failed to download capabilities".
I'd be grateful if someone will tell me what I'm doing wrong. Thanks,
Steve
Here are the specifics.
1. Source of instructions:
https://docs.mapbox.com/help/tutorials/mapbox-arcgis-qgis/
2. endpoint template from tutorial:
https://api.mapbox.com/styles/v1/YOUR_USERNAME/YOUR_STYLE_ID/wmts?access_token=pk.eyJ1IjoicHJvZnNhY2tzIiwiYSI6ImNrbDhnaHFlZTBhb2Yyb25sMThvMTNsd2kifQ.E7N3o-toUEV01DBOt1-FPw
3. endpoint URL with my personal specifics plugged in:
https://api.mapbox.com/styles/v1/profSacks/ckl8hw2rm53v918o7e09ig6mq/wmts?access_token=pk.eyJ1IjoicHJvZnNhY2tzIiwiYSI6ImNrbDhnaHFlZTBhb2Yyb25sMThvMTNsd2kifQ.E7N3o-toUEV01DBOt1-FPw
4. error message:
Failed to download capabilities: Download of capabilities failed:
Error transferring
https://api.mapbox.com/styles/v1/profsacks/ckl8hw2rm53v918o7e09ig6mq/wmts?
access_token=pk.eyJ1IjoicHJvZnNhY2tzIiwiYSI6ImNrbDhnaHFlZTBhb2Yyb25sMThvMTNsd2kifQ.E7N3o-toUEV01DBOt1-FPw&SERVICE=WMS&REQUEST=GetCapabilities
- server replied: Not Found
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210218/117acda3/attachment.html>
