[Qgis-user] osgeo4w shell gdal_calc not running
karsten karsten at terragis.net
Thu Feb 25 21:41:37 PST 2021
Hi All,
I was able to fix this by adding to both PATH and PYTHONPATH environment variables  the dir c:\OSGeo4W64\bin .
It now works if I specify the full path to the python file as
python c:\OSGeo4W64\bin\gdal_calc.py
but not when calling it as gdal_calc (gives and error that the file is not found)
even though that directory is on the PATH and PYTHONPATH as well...
At least I can run it this way again now
Cheers
Karsten
  _____
Sent: Thursday, February 25, 2021 19:36
To: 'Nicolas Cadieux'
Cc: 'QGIS User'
Subject: RE: [Qgis-user] osgeo4w shell gdal_calc not running
Hi Nicolas,
thanks. I tried that route and removed all user folder references to osgeo4w and qgis, then deinstalled and removed osgeo4w completely , and reinstalled osgeo4w.
I still have a problem (and also on a  second machine on windows 10 the same)
though it is now a different error message:
Fatal Python error: initfsencoding: unable to load the file system codec
  File "C:\OSGEO4~1\apps\Python27\lib\encodings\__init__.py", line 123
    raise CodecRegistryError,\
SyntaxError: invalid syntax
Current thread 0x00003064 (most recent call first):
Three is a python27 folder under osgeo4w created after installation not sure that is supposed to be there
Any ideas how to solve ?
Cheers
Karsten
  _____
From: Nicolas Cadieux [mailto:njacadieux.gitlab at gmail.com]
Sent: Thursday, February 25, 2021 17:22
To: karsten
Cc: QGIS User
Subject: Re: [Qgis-user] osgeo4w shell gdal_calc not running
It’s odd that the OSGeo4w shell would ask for a version of Python (2.7) that has not been used since QGIS 2.x.  My guess is that the shell is picking up old configurations.  I would personally uninstall the entire OSGEO4W installation, delete the directories and the user files found in your user profile.   It’s a bit drastic as a solution but that would be my first solution... it would probably take less time than troubleshooting the shell...
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 25 févr. 2021 à 18:26, karsten <karsten at terragis.net> a écrit :
Hi All,
on my updated windows 10 I am trying to run gdal_calc via the osego4w shell (newest version).
I can see gdal_calc when running 0-help. When I try to run it: gdal_calc
I am getting the following error:
Unable to create process using 'C:\OSGEO4~1\bin\python.exe "C:\OSGeo4W64\apps\Python27\Scripts\gdal_calc.py" '
I checked the system path and python 27 is not on the path itself but I have added c:\OSGeo4W64\bin\ . Seems it finds the old python only and that does not appear to run.
Any ideas how to solve this ?
Cheers
Karsten
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210225/8573895c/attachment.html>
