[Qgis-user] Using color_rgba for symbols from field-value
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Wed Jan 20 10:03:37 PST 2021
Hi Richard,
thanx for having a look. First I overlooked this option (gnrr ..), but
then, it did not work :(
My layer is a  point layer of bat species found in batboxes. To this
layer, I join a reference list via the species abbreviation to get the
latin name and the colour.
When I now use this layer to categorize the points by species and set my
rgba-field for the symbol colour, there are still random colours applied
to the categories.
Bug, feature or misinterprestation of the workflow?
Bernd
Am 20.01.21 um 18:53 schrieb Richard McDonnell:
> Hi Bernd,
> I have tested a little polygon dataset, adding a rgba field (as a text string) and found that QGIS will actually use the Field type: string option to apply the colour. Just select your rgba attribute and it works fine.
> hope that helps.
> Reagrds,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> FRM Data Management
> Oifig na nOibreacha Poibl?
> Office of Public Works
> Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 1 647 6543
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Bernd Vogelgesang
> Sent: 20 January 2021 17:32
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Using color_rgba for symbols from field-value
> Hi,
> I would like to hard-wire the colours for categories with their rgba-values in a field.
> I have a text field named "rgba" and am searching for a way to make this color_rgba-function working.
> e.g '146,208,80,255'
> It's obvious that my colour-values are an array of strings, which need to be somehow converted to integers to be eaten by the color_rgba.
> So in theory, the string '146,208,80,255' has to become an array, probably by array("rgba"). But this array is an array of strings and not of integers.
> Does anyone know how to achive this array of integers, so the
> color_rgba(somemagic("rgba") returns my colour?
> Cheers,
> Bernd
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> Email Disclaimer: https://www.opw.ie/en/disclaimer/
