[Qgis-user] QGIS Server Log Stderr
    Thomas Schüttenberg
    thomas at qgis.de
    Tue Jul  6 03:05:11 PDT 2021
Hi Björn,
thanks for investigating, but no, I still don't get this.
With
ErrorLog "${STACK}/logs/error.log"
in httpd.conf (plus LogLevel info to make sure there will be something to log) and
FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
plus FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
in the QGIS server vHost.conf, there is no log output from QGIS server in error.log while restarting the Apache. I would expect the QGIS server summary[1] like I see in the QGIS_SERVER_LOG_FILE, not only the Apache restart lines.
You received the STDERR log on Ubuntu not Windows, right?
I think I stick with QGIS_SERVER_LOG_FILE for now.
[1] https://docs.qgis.org/3.16/en/docs/server_manual/config.html#settings-summary
> pathmapper <pathmapper at posteo.de> hat am 05.07.2021 07:01 geschrieben:
> Hmm, with QGIS_SERVER_LOG_STDERR 1 it works as long as I use the
> standard
> ErrorLog ${APACHE_LOG_DIR}/error.log
> But if I change it to
> ErrorLog ${APACHE_LOG_DIR}/qgisserver.log
> a file ${APACHE_LOG_DIR}/qgisserver.log is created but the QGIS server
> logs are still saved in ${APACHE_LOG_DIR}/error.log
> Thomas, is this the same behaviour you are seeing?
> On 02.07.2021 14:43, thomas wrote:
> > Hi Björn,
> > Am 02.07.21 um 10:58 schrieb pathmapper:
> >> Hi Thomas,
> >> is QGIS_SERVER_LOG_FILE still set in your conf?
> >> Asking because QGIS_SERVER_LOG_STDERR has no effect when
> >> QGIS_SERVER_LOG_FILE is set.
> >> Maybe doublecheck that you restarted Apache after these changes :)
> > Sure, quadruple checked all that ;)
> >> With QGIS server 3.18.1 on Ubuntu LTR it's working as expected.
> > After some research[1] I already suspected it to be a windows specific
> > issue... :-/
> > Or I'm making wrong assumptions about what stderr is, although[2]:
> > "... The error log will also contain debugging output from CGI
> > scripts. Any information written to stderr by a CGI script will be
> > copied directly to the error log."
> > [1]
> > http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-QGIS-server-landing-page-when-running-as-fastcgi-tp5456241p5456373.html
> > [2] https://httpd.apache.org/docs/2.4/logs.html#errorlog
> > Cheers
> > Thomas
> >> Cheers,
> >> Bjoern
> >> On 01.07.2021 15:11, Thomas Schüttenberg wrote:
> >>> Hi there!
> >>> Because file logging support with QGIS_SERVER_LOG_FILE is deprecated
> >>> since QGIS 3.4. I just tried to switch to QGIS_SERVER_LOG_STDERR 1 as
> >>> described in the manual[1].
> >>> Nevertheless the standard error log file I defined in my Apache
> >>> configuration stays silent (Loglevel 0).
> >>> So either I miss something in my config or QGIS_SERVER_LOG_STDERR
> >>> does
> >>> not work here.
> >>> My QGIS server 3.18.2 and 3.16. are installed on a windows server
> >>> 2019, btw. Mayby anyone of you is able to help me with their
> >>> experience? Thanks!
> >>> Cheers Thomas
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
