[Qgis-user] Layer extent
Alexandre Neto
senhor.neto at gmail.com
Tue Jul 6 06:39:13 PDT 2021
Hello Marco,
As far as I remember, there's no GUI interface just for that purpose.
You can change the view on the database side to include that extent
condition. Depending on how your view is constructed, that will probably
trigger the spatial indexes.
Alternatively, you can set a filter on QGIS side, you can use for example
ST_intersects if you are on PostGIS. What I am not sure is if indexes are
used or not. They
Alexandre Neto
User support
www.qcooperative.net
A terça, 6/07/2021, 13:33, Marco Casalboni <casalbonim at gmail.com> escreveu:
> Hi all,
> is there a way to manually set up a layer extent?
> I have a huge view in SQL that is too slow on loading because qgis scans
> the entire view to find the extent.
> An alternative could be instruct qgis to use a specific spatial index for
> a specific layer
> thanks
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210706/f6507cf1/attachment.html>
