[Qgis-user] Point-Layer from GPS-Coordinates
Werner Macho werner.macho at gmail.com
Thu Jul 8 01:18:44 PDT 2021
Hi!
Just a rough guess - maybe you mixed up lat/lon to lon/lat during the
import?
GPS should be in WGS84 (EPSG:4326) so there is not much that could go wrong.
regards
Werner
On Thu, Jul 8, 2021 at 9:27 AM L.W. <eaglelw at gmx.de> wrote:
> Hi,
> I have a MariaDB-Database-Table with GPS-Points (from Phonetrack) an
> want to visualize them in QGIS.
> I imported the table with a dataset-connection to MariaDB and I see the
> plain text data.
> After that I created a virtual point layer by using make_point from lat
> and lon.
> I can see the points on map but they are in the middle of the ocean next
> to south africa and not all over europe.
> I tried different CRS (project crs is 3857 (I do have some other layers
> in this projects with i.e. online routing tool, or other point layers.
> But I can not achieve to move the coords/points to correct position -
> all other layers are right.
> Any ideas?
> Regards
> PS: In generell, which is the "best" CRS for handling with GPS-Coords
> like saved by phonetrack (exported to GPX) or by i.e. Android GPStracker
> (exported as GPX)?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/75370357/attachment.html>
