[Qgis-user] Rasters in print layout are not aligned 3.20
    Drew French
    fullboarfarm at gmail.com
    Thu Jul  8 14:48:26 PDT 2021
Yes they are the same CRS. The weird thing is everything is aligned
correctly in the map canvas, basemaps are where they should be etc...I
switched over to 3.16 and everything works fine there in print layout, but
then when I switch back to 3.20 the problem is still in print layout, using
the same files of course. Anither quirk is if I zoom in, my vector layers
will be correct, but the raster layers change size, ie resolution.
On Thu, Jul 8, 2021, 4:14 PM Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi Drew,
> Check the project CRS and the map item CRS.
> Are those layers not aligned also in the main map canvas?
> Alexandre Neto
> A quinta, 8/07/2021, 19:10, Drew French <fullboarfarm at gmail.com> escreveu:
>> I have noticed that all my rasters, as well as WMS layers, are not
>> aligned in print layout. This tells me that there is a setting somewhere
>> that is wrong. I am using 3.20 on Linux Mint. All the layers CRS are the
>> same. If I could get help with this I would really appreciate it!
>> Drew French
>> (715) 986-8088
>> www.ecologicaldesign.land
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/de5ddb60/attachment.html>
