[Qgis-user] Rasters in print layout are not aligned 3.20
    Tony Shepherd (FarmMaps NZ)
    tony at farmmaps.nz
    Thu Jul  8 15:05:06 PDT 2021
Hi
See my post from Wed 7th July.
I have exactly the same problem since loading 3.20.  By chance do you have label masking enabled on any layers?  I discovered that if I disable the layer masking, then the rasters and vector data will then align correctly.  Re apply masking and then the error pops up again.
It’s a bit of a pain as I have a template that I start new jobs with that has label masking enabled on several layers, so I have resorted to using 3.18 again, but 3.20 does have some cool features.
Cheers
Tony
Tony Shepherd  |  GeoSpatial / Mapping Manager
Ph 027 435 6193  |  E  <mailto:tony at farmmaps.nz> tony at farmmaps.nz
FarmMaps NZ, 3 Kerwood Place, Gore 9740
 <http://tonyshepherd8.wixsite.com/home>  <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Drew French
Sent: Friday, 9 July 2021 6:10 am
To: QGIS List <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Rasters in print layout are not aligned 3.20
I have noticed that all my rasters, as well as WMS layers, are not aligned in print layout. This tells me that there is a setting somewhere that is wrong. I am using 3.20 on Linux Mint. All the layers CRS are the same. If I could get help with this I would really appreciate it!
Drew French
(715) 986-8088
www.ecologicaldesign.land <http://www.ecologicaldesign.land>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/94fcd5e2/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/94fcd5e2/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/94fcd5e2/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210709/94fcd5e2/attachment-0001.png>
