[Qgis-user] Rasters in print layout are not aligned 3.20
Drew French
fullboarfarm at gmail.com
Thu Jul 8 15:24:00 PDT 2021
Thanks, I gave that I try, but it didn't work for me. It is possible I
missed a mask, I'm working on a complicated project. I will try a simpler
project and see if it works.
On Thu, Jul 8, 2021, 5:05 PM Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
wrote:
> Hi
> See my post from Wed 7th July.
> I have exactly the same problem since loading 3.20. By chance do you have
> label masking enabled on any layers? I discovered that if I disable the
> layer masking, then the rasters and vector data will then align correctly.
> Re apply masking and then the error pops up again.
> It’s a bit of a pain as I have a template that I start new jobs with that
> has label masking enabled on several layers, so I have resorted to using
> 3.18 again, but 3.20 does have some cool features.
> Cheers
> Tony
> *Tony Shepherd* *|* GeoSpatial / Mapping Manager
> Ph 027 435 6193 *|* E tony at farmmaps.nz
> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> [image: FM_logo1_small (Custom)]
> <http://tonyshepherd8.wixsite.com/home>
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Drew
> French
> *Sent:* Friday, 9 July 2021 6:10 am
> *To:* QGIS List <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Rasters in print layout are not aligned 3.20
> I have noticed that all my rasters, as well as WMS layers, are not aligned
> in print layout. This tells me that there is a setting somewhere that is
> wrong. I am using 3.20 on Linux Mint. All the layers CRS are the same. If I
> could get help with this I would really appreciate it!
> Drew French
> (715) 986-8088
> www.ecologicaldesign.land
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/82abe45f/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/82abe45f/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/82abe45f/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/82abe45f/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/82abe45f/attachment-0002.png>
