[Qgis-user] Rasters in print layout are not aligned 3.20
    Nyall Dawson
    nyall.dawson at gmail.com
    Wed Jul 14 22:12:18 PDT 2021
On Fri, 9 Jul 2021 at 08:24, Drew French <fullboarfarm at gmail.com> wrote:
> Thanks, I gave that I try, but it didn't work for me. It is possible I missed a mask, I'm working on a complicated project. I will try a simpler project and see if it works.
If you can't track it down can you please open a bug report with a
sample project which demonstrates this?
Nyall
> On Thu, Jul 8, 2021, 5:05 PM Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz> wrote:
>> Hi
>> See my post from Wed 7th July.
>> I have exactly the same problem since loading 3.20.  By chance do you have label masking enabled on any layers?  I discovered that if I disable the layer masking, then the rasters and vector data will then align correctly.  Re apply masking and then the error pops up again.
>> It’s a bit of a pain as I have a template that I start new jobs with that has label masking enabled on several layers, so I have resorted to using 3.18 again, but 3.20 does have some cool features.
>> Cheers
>> Tony
>> Tony Shepherd  |  GeoSpatial / Mapping Manager
>> Ph 027 435 6193  |  E tony at farmmaps.nz
>> FarmMaps NZ, 3 Kerwood Place, Gore 9740
>> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Drew French
>> Sent: Friday, 9 July 2021 6:10 am
>> To: QGIS List <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Rasters in print layout are not aligned 3.20
>> I have noticed that all my rasters, as well as WMS layers, are not aligned in print layout. This tells me that there is a setting somewhere that is wrong. I am using 3.20 on Linux Mint. All the layers CRS are the same. If I could get help with this I would really appreciate it!
>> Drew French
>> (715) 986-8088
>> www.ecologicaldesign.land
> Qgis-user mailing list
