[Qgis-user] Rasters in print layout are not aligned 3.20
    Drew French
    fullboarfarm at gmail.com
    Thu Jul 15 17:17:55 PDT 2021
Will do.
On Thu, Jul 15, 2021 at 12:12 AM Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On Fri, 9 Jul 2021 at 08:24, Drew French <fullboarfarm at gmail.com> wrote:
> > Thanks, I gave that I try, but it didn't work for me. It is possible I
> missed a mask, I'm working on a complicated project. I will try a simpler
> project and see if it works.
> If you can't track it down can you please open a bug report with a
> sample project which demonstrates this?
> Nyall
> > On Thu, Jul 8, 2021, 5:05 PM Tony Shepherd (FarmMaps NZ) <
> tony at farmmaps.nz> wrote:
> >> Hi
> >> See my post from Wed 7th July.
> >> I have exactly the same problem since loading 3.20.  By chance do you
> have label masking enabled on any layers?  I discovered that if I disable
> the layer masking, then the rasters and vector data will then align
> correctly.  Re apply masking and then the error pops up again.
> >> It’s a bit of a pain as I have a template that I start new jobs with
> that has label masking enabled on several layers, so I have resorted to
> using 3.18 again, but 3.20 does have some cool features.
> >> Cheers
> >> Tony
> >> Tony Shepherd  |  GeoSpatial / Mapping Manager
> >> Ph 027 435 6193  |  E tony at farmmaps.nz
> >> FarmMaps NZ, 3 Kerwood Place, Gore 9740
> >> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Drew
> French
> >> Sent: Friday, 9 July 2021 6:10 am
> >> To: QGIS List <qgis-user at lists.osgeo.org>
> >> Subject: [Qgis-user] Rasters in print layout are not aligned 3.20
> >> I have noticed that all my rasters, as well as WMS layers, are not
> aligned in print layout. This tells me that there is a setting somewhere
> that is wrong. I am using 3.20 on Linux Mint. All the layers CRS are the
> same. If I could get help with this I would really appreciate it!
> >> Drew French
> >> (715) 986-8088
> >> www.ecologicaldesign.land
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Drew French
(715) 986-8088
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210715/eafbf1d6/attachment.html>
