[Qgis-user] R: QGIS Server, Lizmap / OpenLayer, QGIS2Web
    Etienne Trimaille
    etienne.trimaille at gmail.com
    Tue Jul 13 08:00:12 PDT 2021
> LizMap (and others like QGIS Cloud, G3W-Suite, etc.) is the easy way as
you don't have to care about hosting and web viewers. But you should
have a look at the demos first to be sure that it fits for your needs,
also it's quite flexible in configuration.
Sorry, I'm just joining late.
Lizmap is a opensource solution that you can install on your own server.
So you need to care about hosting, upgrades etc.
The source code is on GitHub : https://github.com/3liz/lizmap-web-client/
Same for QGIS Cloud which is running QGIS Web Client, also available on
Github.
https://github.com/qgis/qwc2
Same for G3W-Suite : https://github.com/g3w-suite
But indeed, each of these products have also a paid hosting plan provided
by a private company if you don't want to care about hosting.
Le mer. 30 juin 2021 à 17:12, Gerald Kogler <geraldo at servus.at> a écrit :
> On 30/6/21 16:42, Riccardo D'Alvito wrote:
> > Thank you for your reply, it really helped me to understand some of the
> > steps but on the other hand, it triggered more questions.
> >  1. So QGIS2Web doesn't need QGIS Server for online map publishing? Just
> >     take the files that are generated by exporting the project (into
> >     QGIS), upload them to any server and they are visible?
> You are right, just take the generated files and upload them. The server
> only has to serve them, everything else happens client side in the browser.
> >  2. Does QGIS Server contain already the QGIS software libraries or does
> >     it use map viewers such as OpenLayers? For the visualization of a
> >     map using QGIS Server, then, one needs a map viewer like OpenLayers
> >     or Leaflet in which to insert the various scripts?
> QGIS Server offers OGC services like WMS and WFS to serve your tiles
> through HTTP but it doesn't include a map viewer, you have to code your
> own one.
> >  3. Is LizMap then an easier way to not go through map viewer like
> >     OpenLayers?
> So probably, if you need a really personalized viewer with custom
> functionality, you'll have to code your own map viewer. If you need
> standard functionality you should be fine with LizMap. And if qgis2web
> offers enough functionality, just go with it.
> > Thank you very much for your patience.
> > Riccardo
> > *Da:* Qgis-user <qgis-user-bounces at lists.osgeo.org> per conto di Gerald
> > *Inviato:* mercoledì 30 giugno 2021 16:02
> > *A:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> > *Oggetto:* Re: [Qgis-user] QGIS Server, Lizmap / OpenLayer, QGIS2Web
> > Hi,
> > qgis2web exports a static version of your QGIS project to web using
> > OpenLayers or Leaflet as webmap technologies. It gives you some options
> > on export, furthermore you could take the exported code and customize it
> > furthermore. It produces pure HTML+JS+CSS so you could host it on any
> > server.
> > One limitation is that all your data is exported as GeoJSON, so it's
> > only suitable for limited amount of data as loading of big files could
> > be quite slow on web.
> > QGIS Server needs a more powerful server infrastructure as you have to
> > install QGIS Server package with all it's dependencies. It has the big
> > advantage that it serves QGIS projects with all it's symbology exactly
> > as they are shown on desktop. But you have to code your own web viewer,
> > for example using OpenLayers.
> > LizMap uses QGIS Server but offers you the hosting so you don't have to
> > care about server setup and maintenance and the web map viewer based on
> > OpenLayers.
> > Hope that helps
> > Gerald
> > On 30/6/21 15:10, Riccardo D'Alvito wrote:
> >> Morning.
> >> I would like to get information on the differences that there are
> >> between QGIS Server and LizMap and between OpenLayers and QGIS2Web. I
> >> can't quite figure out where the operation of one ends and the operation
> >> of the other begins.
> >> I know I'm getting a little confused so I need some keys to enlighten
> me.
> >> Thank you.
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210713/9f18e9a9/attachment.html>
